Go Back   Automotive Forums Car Chat > Chevrolet > Optra
Old 06-30-2015, 07:41 PM
Ronald GG Ronald GG is offline
I'm having code P0341 come up, replaced the cam poss sensor still stumbles under load
2004 chev optra 2.0 L d-tec engine stumbles under load much worse with ac on. I replaced the cam position sensor and still the same problem. I get battery voltage on one terminal at the cps connector and continuity at the ground wire. The third wire I believe is for the return signal to the ecm. I don't know how to check that. Has anyone had the same problem and found a solution?
Thanks in advance.
