Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 06-30-2015, 10:26 AM
expjoe expjoe is offline
2010 Ford Edge stuck in park
I have a 2010 Ford Edge FWD with 61000 miles and 3.5L engine, and for the past few months it has been very difficult to shift from park, more so when it is cold. when it sits overnight it is very difficult and takes anywhere from 1 minute to 5 minutes to finally release. When the brake is depressed and I squeeze the shift release button, it does not depress all the way, after pressing and holding the brake, releasing the brake a few times it finally releases and I can shift it. Any thoughts?
Old 06-30-2015, 11:26 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 2010 Ford Edge stuck in park
there should be a solenoid that pulls in and releases the stop on the shifter when you step on the brake, it may be worn out or hanging up or need some sort of lubricant. if its column shist should be under the dash, if its has a floor shift its usually inside the console
Old 07-02-2015, 10:54 AM
Thanks, I took it apart last night and cleaned and lubricated it, we will see if it helps!
Old 10-11-2015, 07:48 PM
timd timd is offline
Did cleaning/lubing fix the problem?
