Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-26-2015, 03:39 PM
GraveMrBlack GraveMrBlack is offline
Electrcial goes out randomly
I have a 2006 Dodge Ram 1500 5.7L and every now and then I put my keys in the ignition and the electrical goes out and the truck won't start. I disconnect positive battery cable and wait about 30 seconds and then reconnect and it starts but when it does it starts kind of slow at first like when you leave the head lights on. Today the same thing happened and I went through the normal process but this time nothing happened. Any ideas???
Old 06-26-2015, 10:57 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Electrcial goes out randomly
Check the battery ground wire to where it's attached to the battery and the engine and be sure it's still tight.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-27-2015, 05:27 PM
That worked! It felt tight though. Any other reason the ground could be.doing that?
Old 06-27-2015, 05:59 PM
aleekat aleekat is offline
Because the computer is not seeing a true 12volts.
Post back, that's what makes Forums Work.
Old 06-27-2015, 06:03 PM
Got it. Thanks for the help.
