Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 06-25-2015, 07:42 PM
Fatherchop Fatherchop is offline
Question 240z rb25det swap
I picked up a shell of a 240z I'm going to turn it in to a drift car my ? Are if this is just a straight racecar no ac no power steering and I by a front clip r33 would it be worth it
Or if I buy a swap package engine ecu trans harness what more would I need under the hood like the fuse box but what else is needed? Thanks
Old 06-25-2015, 10:17 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 240z rb25det swap
i would buy the front clip, it will have all the parts and mounts needed to swap it into the 240 saving you chasing lots of other parts needed to change it over
Old 06-26-2015, 05:26 AM
Thanks vette for your reply chasing parts is a pain but the difference between 3200 and 1900 is the biggy for me as far as the mounts go cxracings swap kit bolts straight from the rb25 to the 240z for 400 bucks. I don't need stuff like heater coil or the lines ac and lines brake stuff power steering Or the radiator or intercooler I'm going to buy that stuff upgraded aftermarket After all that how much more is in that front clip is needed? Thanks
Old 06-26-2015, 11:51 AM
Crvett69's Avatar
make sure you get a complete uncut wiring harness and the maf and ecu and any other parts not mounted to motor needed to run. the front clip would also have stuff like upgraded braking system but your right it will cost more. if you are good at fabricating you could always shoehorn in a twin turbo vg30, they make 280-300hp stock or the rb26 twin turbo that makes almost as much at 270hp
Old 06-26-2015, 10:29 PM
Lightbulb Re: 240z rb25det swap
Sup just came back from the round 4 formula drift today and I was walking in the pits and I came across wiring specialties a company that makes plug n play harness they had a rb26 on a stand running with just the maf spark box and ecu there plug n play for the rb25det cost 650 so screw the half cut as long as I can swing a maf and spark box ow plus a drive shaft I'm good an engine swap kit will work just fine let's tally engine swap kit 1900 plug n play harness 650, mishimoto rad call it 300, intercooler 200 plus piping, cxracing engine and transmission mount swap kit 400, cxracing oil pan 400, that's 3850 the front clip the lowest I got the guy go to was 3200 a dif of 650 and with the front clip I would of bought all those parts on top of it all those parts plus the front clip would of cost me 5150 saving me 1300 forget the clip with that 1300 I can get fuel cell pump and other such things thanks I hope this helps someone one day
Tags
240z' , drift , rb25' , swap'
