Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 06-23-2015, 07:00 AM
red corvette red corvette is offline
Cool shake/vibration
1981 Corvette rebuilt/restored. 35+ mph. steering wheel shakes/vibrates. Higher speed, depress clutch, smooth ride. HELP!
Taken to mechanic recently, test driven to acknowledge, lift done twice, no clue.
Tim
Old 06-23-2015, 12:13 PM
maxwedge maxwedge is offline
A990 racer
Re: shake/vibration
So you are saying while the steering wheel is shaking, depressing the clutch causes it to stop, this isn't happening because the car then slows down?
Old 06-24-2015, 08:34 AM
Re: shake/vibration
It is happening, the vibration is not a side to side, it is an up and down. Yes, the vibration goes away when the clutch is depressed, yes the car slows but no vibration!
Tim
Old 06-24-2015, 11:33 AM
DeltaP DeltaP is offline
Re: shake/vibration
If the vibration quits suddenly when depressing the clutch then check eng,trans mounts and driveline. I'd also give a look at the crankshaft vibration damper.
Old 06-25-2015, 12:24 PM
Re: shake/vibration
What I remember at the shop, they did check engine mounts and claim trans. was OK.
Crank ?
Where do I check!
It is very hard for me to understand shake/vibration, but all responses are learned and appreciated.
Tim
Old 06-25-2015, 05:26 PM
777stickman 777stickman is offline
Re: shake/vibration
Basically, from your description, the vibration issue is engine and/or clutch related. You should be able to duplicate it in the driveway with the tranny in neutral and the clutch out. Get the motor up to the rpm's where the vibration occurred on the road.
You say this motor was just rebuilt. Was it internally or externally balanced? Is it a small block or big block? Is the motor original to the '81?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
