Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 06-16-2015, 09:46 PM
carl80 carl80 is offline
1988 fiero se been sitting for 20+ years. Brake issues
I bled the brake. And they work fine under light load but if you need to stop fast it feels like you have no power brakes at all.
Old 06-18-2015, 06:05 PM
MikeCStig MikeCStig is offline
Re: 1988 fiero se been sitting for 20+ years. Brake issues
If you continue to drive that car you are going to die, it will kill you. Any car left sitting over 2 decades is going to be a nightmare.
So let's say you do get this issue with the brakes sorted out, what's next? Who knows what else is going to go wrong that just hasn't yet.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
The Following User Says Thank You to MikeCStig For This Useful Post:
igor@af (06-18-2015)
Old 06-23-2015, 09:37 PM
Tech II Tech II is offline
The under bodies of these cars were known to rust out, if the car was from a salt area, like New England....
Did you ever have this put on a lift and inspected from below?
Old 06-27-2015, 06:53 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Brake booster diaphrams tend to go hard after a while. Could have a vacuum leak to the booster. Brake pistons could be gooped up in the bores.
My '88 Formula brakes never worked well when cold. Worked fine when warmed up.
Oh well...
Oh yeah, never was an SE in '88.
Lineup was--
Fiero -- notchback with 4 cyl,
Formula-- notchback with V6,
GT-- sloped nose, fastback with V6.
Old 08-06-2015, 06:42 PM
rayray007 rayray007 is offline
It's for the love of the car!!!
This little car is actually worth putting money into to fix up. God I loved my Fiero. I looked like a whale in a sardine can, but it was a great car!!!!!
You're most likely gonna have to replace the entire brake system, Booster, Master, Calipers, drums, ect.... Sitting this long, you have an uphill battle, but if the car body is solid, it's a sound investment!
just my 5 cents
Old 08-11-2015, 05:02 PM
Old Lar's Avatar
Old Lar Old Lar is offline
After sitting 20 years a lot of rubber things dry up and need to be replaced. The Fieros that I own get a lot of maintenance money spent on them. The last time I have taken my cars (two of the three I own) to the shop there has been a $1500 tab for repairs. My 87 GT is going in in a couple of weeks as It hasn't been driven much since last year and I plan on a road trip in September. I've had the car since new and with 155+K miles on the car it gets lots of maintenance. I know that the DS axel boot is leaking and may get new wires, plugs and what ever else it may need.
