Old 06-12-2015, 12:11 PM
khairy1974 khairy1974 is offline
Mixing Finishers Urethane Clear GP1
Hi everybody....
Does anyone knows how to mix the finishers GP1....
The instruction is in Japanese and what are the contents of each individual bottle?
Old 06-12-2015, 03:16 PM
stevenoble's Avatar
Re: Mixing Finishers Urethane Clear GP1
You have a clear coat, a hardener and thinner. Whatever quantity of clear you add you need half as much hardener, for example 50 ml of clear, 25 ml of hardener, the ratio is always the same. You can vary the thinner amount but usually between 10 and 30% is good. Personally I go more on the thinner to make it flow better, but it's down to personal choice. Hope this helps
Steve Noble
The Following User Says Thank You to stevenoble For This Useful Post:
khairy1974 (06-12-2015)
Old 06-12-2015, 05:52 PM
Thanks steve....
