Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-05-2015, 03:18 PM
bharrison3812 bharrison3812 is offline
1994 dodge pickup oiling issues
Ok guys I've got a1994 dodge ram 1500 with a 318 cam bearings are good new oil pump new oil pump drive pin getting oil to the filter and that's as far as it gets no oil pressure and no oil to the top end any ideas? Me and a couple engine builders are stumped!
Old 06-06-2015, 07:32 AM
MikeCStig MikeCStig is offline
Re: 1994 dodge pickup oiling issues
There may be a clog I an oil passage leading from The filter back through the block to the top end. There are oil additives that could he'll sort this mess out, just go to your local auto parts store and ask about additives that help dissolve built up gunk. If that does't work, you may just have to tear the whole engine apart and clean every oil passage out, check for deformed gaskets and seals and all kinds of sh¡t. Kind of surprising I've always thought the 318 was a a strong reliable engine.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
