Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-30-2003, 10:00 AM
Leaper Leaper is offline
New flywheel?
Is it worth the money to get a lighter flywheel for my H22 conversion project? I know its a matter of opinion. But is the cost/benifit worth it. Dropping the engine into my 2001 Accord and I plan to turbo and nos the setup in the future.
Old 06-30-2003, 10:39 AM
del del is offline
móddə rąytər
here's the thing. it's gonna make your car harder to drive, not to mention launch good. if you like to drag race, i would actually suggest not getting a lighter flywheel. but if you auto-x a lot, then yeah a lighter flywheel would help. for daily driver, i don't think it's worth it. the engine will rev faster and and more freely, but it's just a bigger pain driving on a daily basis. if you're willing to accept all that, then go for it, you'll also lose a few pounds, which always helps preludes.
Old 07-08-2003, 08:54 PM
How does it make the car harder to drive on an everyday basis? I understand the RPM would drop further down between shifts with a lighter flywheel but wouldnt the car get to the turbo RPM range faster thus making the car faster say in the short runs?
Old 07-09-2003, 12:00 AM
strodda strodda is offline
thanks fot the info there del, i was considering getting a new flywheel, but now im not going to. i wouldnt mind the extra lowend power, but i dont want to compromise daily driving, since thats all i do.
Old 07-09-2003, 12:53 AM
del del is offline
móddə rąytər
basically you have to rev higher just to get the car going. and when you're starting off on a hill, it gets even tougher. easier to stall. i guess once you're used to it, it's fine. but you don't have the momentum with a lighter flywheel that you have with the heavier one. at least with a heavier one, that momentum you get when the engine spins actually helps you. it's a matter of physics, a subject that i failed to master in college. i can't really explain in words without confusing you, but if you think about it a minute, it makes sense.
Old 07-09-2003, 08:10 AM
Hadnt thought about it in that way before. Makes sense now, thanks.
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 11:38 AM
new flywheel 94accordlx1 Accord/TSX/Accord Hybrid 2 08-31-2005 06:51 PM
Starter problem... new flywheel just installed wyltk55 3000GT/Stealth 4 04-24-2005 10:27 AM
Need new flywheel for a 4g64 help Trueeclipse Off-Topic 8 03-14-2005 10:13 PM
What is a Y pipe and how much would a new flywheel help? krislewis21 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 09-10-2001 04:10 PM
