Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 05-29-2015, 07:06 PM
comet240 comet240 is offline
00 bleeding brakes order
hi
i was bleeding brakes on my sisters truck... cant really start truck i got a pissing fuel line that i have in a different topic
but
it uses a shared brake line in the back spliter
i had 3 leaks from my fittings i made i tightened them after tigher as i never know how tight your supposed to tighten your double flares
but i did the Right Rear then the Left Rear then Right Front Left front
with a helper pumping the brakes..
but it didn't help when i started truck to move it she took off when i put it in gear had to shut off and use the emerg brake
but is the sequence
Right Rear
Left Rear
Right Front
Left Front
i put new calipers and brake flex and pad and new lines.
i put new line to the back and 3 flex lines and 2 brake lines one to each side
so they were a dry system
or do i need one of those vacuum pump bleeders? etc
