Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-28-2015, 10:01 AM
rodney1c rodney1c is offline
1996 Ram V10 engine nocking/ticking
I am hoping somebody can help me figure out the problem with my truck. I have a 1996 Ram with the V10 that only has 10,000 miles since it was replaced by Dodge. 7 years has passed since that shortblock warranty job. It now has a tick/knock that I cant seem to locate? I changed the lifters and one push rod since is was a little bent and put it all back together. Still getting the same thing - nothing has changed and I am looking for somebody who may have the fix?
Thank you for any advice!!
Rod 209-640-1643
Old 05-28-2015, 07:22 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1996 Ram V10 engine nocking/ticking
Pull one spark plug wire at a time while the engine is running and see if the noise is coming from 1 particular cylinder. Put the pulled wire back on before going to the next wire.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 05-29-2015, 09:07 AM
Thanks for the advise, I will try tonight and post the results.
Rod
Old 05-29-2015, 09:31 AM
astep astep is offline
Rod 209-640-1643
Old 06-04-2015, 05:51 PM
I did pull each wire one at a time and the knock never stopped? I also heard it could be the timing belt tensioner?
Old 06-04-2015, 09:28 PM
AF - Advisor
Good work.
I don't think the V-10 has a timing belt, most likely a timing chain but they can be noisy too.
I think I'd be pulling the valve covers off and check for loose rockers and or broken valve springs.
Does the engine otherwise run smooth?
Old 06-08-2015, 05:08 PM
I got under truck with thesescope and could really hear the knocking toward the middle of the oil pan? My guess the rod bolts have loosened up. I only have 10000 miles on the engine since Dodge did the long block replacement. I called a service manager at Dodge dealership today, I request that they drop the oil pan and see if something has come loose. I am wondering if they will honor anthing if it was something done wrong at assembly. The new engine was done on the truck in 2006. I figure best to let them drop the oilpan to inspect instead of me? The last thing I want them thinking is that I did something.
Old 06-08-2015, 05:12 PM
Originally Posted by Chris Stewart View Post
Good work.
The truck runs smooth but once warm the knock appears and follows with idle speed?
I should have bought a diesel when I ordered a new truck.
Old 06-08-2015, 08:58 PM
AF - Advisor
How much warranty is on that engine?
Old 06-10-2015, 08:48 AM
Its not under warranty because I let the time lapse. This morning I started just to listen - no noise but after warm up it started knocking again. I told the service manager that I want him to be there when they drop oil pan. I think a rod bolt came loose but since I never dropped the oil pan - I think it would be better if dealership dropped it.
Thanks for your message
Old 06-10-2015, 09:36 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
if a rod bolt came loose the rod would probably have come though the pan or block by now. its more likely you have a rod or main bearing knock, they will get louder as engine warms up and oil gets thinner. hopefully its something else making the noise or engine will have to come out and be rebuilt again
Old 06-10-2015, 05:48 PM
AF - Advisor
Yup. a loose rod bolt will knock all the time.
Piston slap from a worn piston will be more pronounced as the engine warms up too.
Do you have the correct viscosity oil in the engine?
Old 06-14-2015, 07:01 PM
AF - Advisor
Boy am I wrong about that, the piston slap is more pronounced when it's cold, before heat expands it.
The forged pistons in the early Z28's were noisy until the engine/pistons warmed up due to extra piston to cylinder wall clearances.
Old 06-16-2015, 05:56 PM
Thumbs down Re: 1996 Ram V10 engine nocking/ticking
Well after taking it to local Dodge, I got a teardown fee of 465 on top of the 165 diagnostic to tear it down fee. I am pulling my truck out of there tonight. They still think its a rocker or spring.
Old 10-21-2017, 10:06 AM
Well I am taking my truck to have the upper end torn down. The knock is still there after 5000 miles and 2 years later. Changed oils and spark plugs. Need to have them tear it down and figure this out. Keep you posted..
