Go Back   Automotive Forums Car Chat > Ford > Fiesta
Old 05-27-2015, 02:27 PM
perry123 perry123 is offline
oil cap 01 fiesta
I have a 01 fiesta zetec. The oil cap will not come off. How can i do it?
Old 05-27-2015, 03:16 PM
aleekat aleekat is offline
Re: oil cap 01 fiesta
You're not the only one. https://www.google.com/search?q=01+f...utf-8&oe=utf-8
Post back, that's what makes Forums Work.
Old 05-27-2015, 03:20 PM
Originally Posted by aleekat View Post
mine is not a pull out one . you turn clockwise to close till it clicks. anticlockwise to open
Like this
http://www.ebay.co.uk/itm/FORD-ZETEC...item2c7e7da29c
Tried first thing in morning before starting and after driving. Tried a cloth for more grip and used some wd 40 oil around it. won't budge
Old 05-27-2015, 03:49 PM
Like this
Had a dodge that just kept clicking trying to remove it. Go buy a new cap because you'll bust yours up removing it. First answer was how I removed mine. Scroll down for a drawing. http://www.focusfanatics.com/forum/g...mming-off.html
Old 05-27-2015, 03:55 PM
Mine only clicks when turned clockwise i.e to close. Won't budge or click anticlockwise
Old 05-27-2015, 05:51 PM
Then my guess is there is a rubber seal that over time, heat, etc has bonded to the cover. Have you tried removing it when the engine is hot? Other that that. Small taps with a block of wood with a hammer or big pair of pliers. Like I said earlier, have a spare handy.
Old 05-27-2015, 05:53 PM
tried hot and cold
Old 05-27-2015, 06:24 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
if its due for a oil change take it to a shop and let them get it loose when they do the oil change. bet they just put a large set of slip jaw pliers on and turn, will come loose or break
Old 05-28-2015, 05:24 AM
not oil change just want to top up
Old 05-28-2015, 07:14 AM
Crvett69's Avatar
i would say you have several options, take it to a minute lube type place or your mechanic and ask them to get it loose for you, use a large slip nose pliers or piece of wood and a hammer or a strap wrench, or remove valve cover and take it to someone that can get it off for you like a machine shop. i would use the wood and hammer or the slip nose pliers myself and if you break it you would have to replace it anyway. might want to get a new one first so you don't have to stuff a rag in the hole while you drive down to get a new cap
Old 05-28-2015, 08:13 AM
Got it. many thanks. Used a piece of wood and a rubber mallet like
http://www.amazon.co.uk/Blackspur-HM...2818310&sr=1-3 to loosen and then got it open with hand and a cloth around it
The cap is ok does not seem damaged. Closed and opened it several times to check.. Thanks guys
