Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-25-2015, 09:15 AM
Kooolman Kooolman is offline
Chevy Caprice does not start after driving in summer
I have chevorlet caprice 2006 LTZ, whenever I switch off my car after running with AC on (means heat shows 50%) does not start. It simply cranks up but does not start,I try 3-4 times it starts, everything works fine . It starts perfectly in morning or after idle for long time. What stops the start, is it the fuel pump? I did computer scan but nothing detected.
Please I am clueless and need help!
Thanks
Shahid
Old 05-25-2015, 12:37 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Chevy Caprice does not start after driving in summer
Fuel filter, perhaps. Could also be a weak fuel pump. If you can get a pressure gauge, hook it to the fuel rail diagnostic port and see what the pressure is. It should usually range about 50PSI +/- 15PSI.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-25-2015, 01:41 PM
Blue Bowtie's Avatar
Registered Offender
Fuel bleed-off is also a possibility. This can be through injectors or a pressure regulator, although the regulator in an '06 may be in the tank, making that less of a possibility. If the leakage is through the injectors, the accumulated fuel will flood the engine. After several hours of sitting, the excess fuel tends to evaporate, allowing a normal start.
As the SandMan indicated, a pressure gauge will be very helpful. Not only should the standing fuel pressure be checked, but after the pump is off monitor the residual pressure to see how quickly it drops.
Another thing that may help starting after heat-soak is to invoke the Clear-Flood Mode by holding the accelerator to the floor while cranking. Be ready to release it IMMEDIATELY as soon as the engine starts. Opening the throttle past 80% not only admits more air to dilute any accumulated fuel, but also cuts off injector pulses while cranking to prevent further flooding.
Old 05-26-2015, 10:53 AM
j cAT j cAT is offline
Thanks
Shahid
what engine you have in this caprice LTZ ? V6 OR the 6 LITER V8 ?
these are not available here in the US...
if you get the engine to start when hot , with the throttle pedal down , then you may have fuel problems like bad/dirty injectors.
make sure the radiator is clean / wash the radiator anyway..
http://www.drivearabia.com/ultimatec.../2005-2006-/12
Old 05-27-2015, 01:56 AM
Thanks guys for your support. It's v6 ltz and its does not have option to check fuel presure guard. I took it to mechanic and he also could not find any problem. When it's cool down it starts perfectly.
Old 05-27-2015, 09:38 AM
Today I took car to mechanic and he did computer scan and displayed following error"Fuel pump Relay Ciruit Malfunction"
Any clue what does it mean of above error?
Old 05-27-2015, 12:06 PM
with hot temps these relays can fail because they get too hot. this could be the problem. have the relay replaced but keep it. if it seems to work for a few days put the old relay back in just to be sure it is the relay not just a bad fit in the relay socket/connector. GM had problems with relays controlling the cooling fans and this causes engines to overheat. it is called coil saturation when the coil heats up too much/draws too much current. good luck ..
The Following User Says Thank You to j cAT For This Useful Post:
Kooolman (05-28-2015)
