Old 05-23-2015, 01:32 PM
sbcb62 sbcb62 is offline
2008 Caravan SE Brake warning light
I'm working on a 2008 Grand Caravan SE 3.3L
Brake warning light (!) on dash is on. Datastream on my OTC Genisys shows that the Brake fluid level switch is 'ON'.
The van does not have pad wear indicators; fluid is full; there are no leaks in the system; no brake pull, uneven braking or other performance issues.
Scantool says Park Brake is off and I disconnected it to be sure.
When checking connector at switch on the master, one wire has continuity to ground and the other has about 12.5V on the DMM but won't light my test light.
I subscribed to Haynes on-line manual but there are no schematics for this circuit. If anyone has the wiring diagram or any suggestions, it'd be much appreciated.
Thanks!
Old 05-23-2015, 10:46 PM
georgef61 georgef61 is offline
Re: 2008 Caravan SE Brake warning light
Does the (!) refer to this symbol ?:
If yes, that is the tire pressure monitoring light.
Check the BBB industries tech database for wiring diagrams:
http://www.bbbind.com/tech_database.html.
"BBB Industries provides FREE access to our database of Technical Service Bulletins (TSB’s) and Wiring Diagrams for all automotive applications, makes and models. You are free to read, download and print the complete TSB (not just title and description) and all wiring diagrams"
You will need to register to access the information.
2009 Dodge Grand Caravan SXT (3.8) 200,000+ miles
2001 Dodge Grand Caravan Sport (3.3) 250,000+ miles
2003 Dodge Grand Caravan eL (3.8)
Old 05-24-2015, 08:23 AM
I managed to find a wiring diagram yesterday and the the circuit should actually be a 5V circuit. Ohhmed out the wiring between the fluid level sensor and the TIPM. Good continuity and no shorts to ground or B+.
I'm thinking the TIPM is fried but the things are foolishly expensive. Any thoughts before I go and drop $500 on this thing?
Old 05-24-2015, 05:02 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
I take it there's no continuity through the switch?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 05-28-2015, 11:03 PM
I was surprised to find that it's actually not a switch. It's a variable resistor sensor. Spec says 9000-11000 Ohms and it is within spec.
The wiring diagram symbol is:
Tags
dash , level , lite , warning
