Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 05-23-2015, 10:47 AM
Brandon505 Brandon505 is offline
How do you cut aluminum tubing?
I got some aluminum tubing from spectre performance to fix a problem with my air filter and need to cut it to be an inch long (its 4 inches), will a hacksaw work for this?
Old 05-24-2015, 01:12 PM
534BC 534BC is offline
Re: How do you cut aluminum tubing?
If this is 4" diameter then you might be able to make two pipe cutter rings around it one inch apart. Then cut it with a saw. It's gonna be rough. A lathe would be better , a pipe cutter would be ok too. If it's small tubing that is only 4" long then a tubing cutter will work.
