Old 05-20-2015, 09:47 AM
Mike2035 Mike2035 is offline
06 Excessive outside tire wear both sides!
Ok I have an 06 trailblazer, that is getting excessive tire wear on the outside. I have had to replace the wheel hubs on both sides and both tie rod ends. The outside wear on the tire is going fast. How can I adjust it myself? Do I do it from the tie rod? Replacing front tires is killing me. Thanks!
Old 05-20-2015, 11:37 AM
aleekat aleekat is offline
Re: 06 Excessive outside tire wear both sides!
You really need to get it professionally aligned. I prefer Hunter alignment machines and a tech who knows how to operate the machine. I use goodyear here locally. Only shop I use for alignment. If you decide them, go online. They usually have coupons/specials etc. If you want to try and do it yourself, google DIY alignment.
Post back, that's what makes Forums Work.
Old 05-21-2015, 02:24 AM
Schurkey Schurkey is offline
Two main reasons for wear on the outsides of the front tires: Excessive positive camber, and excessive toe-in. There are other causes--carrying too much speed into corners can do it, among other things--but camber and toe are the main ones.
Replacing the tie rod ends improperly could result in excessive toe-in.
Whether camber or toe, you need it aligned. I care less about the equipment than I do about the person using it. It's getting harder to find a competent alignment tech.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
