Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 05-12-2015, 01:07 PM
bsr2002 bsr2002 is offline
Question how to clean throttle body on 2005 equinox
Hi all,
I just bought a 2005 Equinox and the Throttle Body looks really dirty. I'm trying to remove it but the bypass rail is in the way. I tried to pry it a way with a screw driver but it would only go so far. I'm I missing out on something???
Thanx in advance!
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 05-12-2015, 02:19 PM
rkvons's Avatar
rkvons rkvons is offline
Re: how to clean throttle body on 2005 equinox
Originally Posted by bsr2002 View Post
Hi all,
Thanx in advance!
The bypass rail is bolted to the throttle body. Did you remove the nut that holds it on?
Old 05-12-2015, 05:20 PM
Yes I did, but the rail will not go over the studs. Do I have to remove the whole rail??
Old 05-13-2015, 02:52 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Just remove the studs. That's far easier than messing with the coolant rail. The correct size for the studs is a really small E?? socket (reverse Torx), but I used a regular 4mm hex socket when I cleaned the throttlebody on our Equinox. The service manual says you must replace the studs if you remove them, but I see no reason to do this if they don't appear to be damaged after removal. The manual says they only need to be torqued to 53 lbs-in. If you tighten them up a touch over snug that will be plenty tight; likewise for the throttle body nuts.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
The Following User Says Thank You to Ruley73 For This Useful Post:
bsr2002 (05-17-2015)
Old 05-17-2015, 01:10 PM
Thank you , I picked up some e_sockets at Harbor freight!
Tags
body , chevy , equinox , throttle
