Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 05-11-2015, 10:08 AM
indy4311 indy4311 is offline
2001 Tahoe AC problem
2001 Tahoe AC problem.
blows hot air, front and rear. Full charge. Compressor kicks in and turns. New orifice tube (old one was not clogged). Pipes/tubes are cold like they are supposed to be.
Please help.
Old 05-11-2015, 03:35 PM
j cAT j cAT is offline
Re: 2001 Tahoe AC problem
Please help.
so what was the problem always hot air ? then you opened up the ac system ? when you troubleshoot ac systems you use pressure gauges. low/high pressures then see how they line up with the air temps. hot air would be the temp stepper motor .this moves the temp door. I guessing you have electronic ac so then this computer may be bad. try resetting the ac control computer.
Old 05-12-2015, 09:25 AM
problem solved . . . actuator
thanks
Old 05-12-2015, 04:17 PM
thanks
I have found the temp door actuator is binding this stresses out the motor... so I installed 2 small washers on the assy to have a space away from the air box .
Old 05-13-2015, 09:49 AM
thanks for the tip.
Tags
a/c , tahoe
