Old 11-14-2001, 07:49 PM
Steel's Avatar
Steel Steel is offline
Tightening or replacing belts?
yah, i got a 93 pathfinder, and the engine is squeaking me to the brink of insanity. Im sure its the belts on the engine. if there's a way....shoul d i tighten them, or just replace them all?
Old 11-14-2001, 08:22 PM
Seabass Seabass is offline
How many miles since they got changed?
If they are loose (push/tug on them.....if they move quite a bit they are too loose, they should be firm...but still move).
If they look worn or cracked then you should go ahead and install new ones.
Till then you can take a bar of soap to it and it should keep it at bay.
Seabass
Down with vB and UBB Code
HTML Or Death
<blockquote type=cite><blockquote><hr><center>"In the quiet words of the Virgin Mary.....come again?"<center><hr></blockquote></blockquote>
Old 11-14-2001, 09:31 PM
Steel's Avatar
soap? like, rubbing soap all over the inside of the belts? hmm...if that kills the sqweaks
Old 11-15-2001, 04:07 PM
Steel's Avatar
wow, it worked!! thanks seabass!
Old 11-15-2001, 05:08 PM
You'd be surprised what you can do with soap :-)
I haven't done that "trick" for a long time. Get them belts taken care of.
Seabass
HTML Or Death
