Old 05-10-2015, 12:34 PM
hammeron hammeron is offline
2000 chev 2500
Had a loud bang in rear of truck driving down the road. Seemed like the diff blew out. As it rolled to a stop could hear a ticking noise coming from the rear end. Stopped checked everything seemed fine. Drove ok after all the way home. Happened again when hit a bump in the road. Stopped again to check everything looked ok. Whats up with that?
Old 05-10-2015, 05:47 PM
j cAT j cAT is offline
Re: 2000 chev 2500
check the leaf springs/spare tire holder
Old 05-10-2015, 06:01 PM
Re: 2000 chev 2500
Springs are fine. Axle seals were changed in the fall. Sometimes it will clunk really heavy when I accelerate after backing up. Universal joints are ok.
Old 05-10-2015, 06:29 PM
777stickman 777stickman is offline
Re: 2000 chev 2500
If you have the G80 locking rear end, it could be an issue with that. For sure, pull the cover and look for any thing wrong.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 05-10-2015, 07:32 PM
Re: 2000 chev 2500
It has a normal rear end no limited slip.
Old 05-11-2015, 08:16 AM
Re: 2000 chev 2500
with a 2500 if its 2wd then very possible you have OPEN DIFF.. If you have 4WD then you have the eaton locker diff. with this type diff I would also recommend removing the diff cover and rotate the axles to inspect all the gear teeth and any other metal . wash out with mineral spirits paint thinner low odor is what I use and install the 75-90wt synthetic gear lube .. I use the mobil gear lube. how many miles on this ?
check RPO codes for gear type /diff type..
Old 05-11-2015, 10:05 AM
Re: 2000 chev 2500
Yeah I will take the cap off and check that out. There is 230 ks on it. Thanks everyone for your help. I will get back with what I find.
