Old 05-05-2015, 09:43 PM
rustyabiding rustyabiding is offline
Radiator Replacement Question
Hi I have a 2002 alero with the 3.4 engine. I need to replace the radiator. According to the Haynes repair manual it says you need to evap the A/C system and pull the radiator from the bottom. I was wondering if anyone has done this job without evaporating the A/C? I would like to keep the a/c lines intact and remove the radiator. Also has anyone removed the radiator from the top or is removing from the bottom the way to go? Thanks in advance!
RustyAbiding
Old 05-05-2015, 10:37 PM
MikeCStig MikeCStig is offline
Re: Radiator Replacement Question
If the manual says evaporate the a/c, do it. There's probably a very good reason the instructions say to do that. My guess: leaving the system charged is dangerous, maybe there a risk of getting refrigerant all over you, resulting in a nasty reaction between the chemical and your skin, eyes, lungs,etc. You'll just have to recharge the a/c afterwards, which isn't exactly rocket science.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 05-06-2015, 02:59 PM
Haynes wants you to relive the A/C because it wants you to remove the line from the compressor to the condenser. I wanted to see if anyone got by without unhooking that line. It looks like the radiator could fit through without removing the line.
RustyAbiding
Old 05-07-2015, 07:51 AM
Tech II Tech II is offline
They want you to "evacuate/recover" the refrigerant in the system, possibly because the condenser may be attached to the radiator, and it's not possible to get to the screws that attach them together, or maybe they are interlocked so the radiator can't be removed form that position.....thus you disconnect the lines to the condenser, and remove the condenser and radiator as a unit....then you separate them....
Old 05-09-2015, 06:20 PM
Got done replacing the radiator. It can be done with out discharging the A/C. Two bolts coming from the front hold the condenser to the radiator and require an 11 mm socket. After those are removed nothing needs to be moved on the A/C end.
RustyAbiding
