Old 05-04-2015, 09:41 PM
88Porsche944 88Porsche944 is offline
need to narrow parts
What is the best way to cut the body parts, diagonal or vertical for the best fit when reattaching?
Thanks,
Trevor
Old 05-04-2015, 10:35 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: need to narrow parts
Can you be a bit more specific? I'm not sure I follow.
PHOTOBUCKET SUCKS
Old 05-04-2015, 11:09 PM
I'll try. I've got a front and rear end of a car that is too wide to fit the car I want it to go on.
Old 05-05-2015, 03:39 AM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
I always use a Dremel power tool with the thinnest available cutting wheel for such works on body parts. If you have a steady hand, and and cut in the right direction, so the excess material will be on the inside of the body, you get a very clean cut, that will be easy to repair.
Or you could use a photo-etched saw, or some other kind of very thin metal saw blade. Their cuts can be even thinner, but you have to be more careful in the beginning, so you saw just in one spot and not all over the place.
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
The Following User Says Thank You to Kjenjak For This Useful Post:
88Porsche944 (05-05-2015)
Old 05-05-2015, 11:02 AM
I'll be a using P.E. saw blade. I don't have much luck with the Dremel.
Old 05-05-2015, 01:32 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
you could use a few layers of electrical tape to mark the border for what you'll be cutting if you're using a dremel. that way, if you do slip, it'll cut the tape first and you can still be on-track.
for large areas, i use the router. for smaller ones, i just use a PE saw.
olly olly oxen free
Old 05-08-2015, 07:02 AM
GTRfan01 GTRfan01 is offline
the dremel will work but i wouldnt use a abrasive cutting disc, they just melt the styrene, the mini PE saw cutting wheels that are sold to fit a dremel however cut through very nicly, make sure you use a fine one though.
just dont slip
Old 05-08-2015, 07:24 AM
MPWR's Avatar
I've heard (but have not tried) that heavy duty sewing thread can be used to cut along panel lines. I've been tempted to try using thread held on a flexi file frame.
Sooner or later I expect I'll try it. I just haven't yet felt much need to cut apart any bodies.
PHOTOBUCKET SUCKS
The Following User Says Thank You to MPWR For This Useful Post:
88Porsche944 (05-08-2015)
Old 05-08-2015, 09:23 AM
yelo yelo is offline
It work, i've done it... I even made a bigger frame similar to a flex i file, about a foot long for easier acces and longer stroke
The Following User Says Thank You to yelo For This Useful Post:
