Brakes issue ?
Hello, My Camry XLS have pulsation when brake pedal is applied. The pulsation get increased with the speed and very noticeable at 60 -70 mph.
Is it front or rear break issue ? If you think rotors has to be re-surfacesd should I also change pads ? Thanks for you help |
Re: Brakes issue ?
This sounds like what happens when the rotors are worn unevenly or warped, which is usually caused by pads that should have been changed a long time ago. If the rotors are worn, they can probably be resurfaced. If they're warped, they probably need to be replaced. Get them checked, then get them checked again by someone else. A second opinion is always a good idea. Don't go to a dealership unless you have a warranty through them, because they'll likely try to rip you off.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!" -James May, in an old, worn out Lamborghini purchased for less than £10,000. |
| The Following User Says Thank You to MikeCStig For This Useful Post: | ||
Valerian (11-04-2015)
