Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 05-04-2015, 06:38 PM
JRSpann JRSpann is offline
2003 crv imrc (imtv?)
My "Maint Req'd" light came on and stayed on, so I went to Auto Zone for a diagnosis. The fault code is P1077, and diagnosis is IMRC valve stuck short, Open or short circuit condition, failed IMRC actuator.
I've found very little info about this on the Internet. Is this something I should expect to be able to tackle myself, or do I need to submit to highway robbery at a dealer?
Thanks
Old 05-04-2015, 11:26 PM
MikeCStig MikeCStig is offline
Re: 2003 crv imrc (imtv?)
Im not sure what that is or if you can do.it yourself. If you can't you don't necessarily need to go to the dealer. Go to a few small, privately owned shops (preferably one that specializes in Japanese cars) tell them what the problem is ask if they can fix it, and if so, what's the price.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
