Old 05-03-2015, 09:31 PM
marisalee marisalee is offline
torque wrench socket
I have a deep impact socket used with an air impact wrench to remove wheel nuts.
May I used the same deep impact socket with a torque wrench to tighten my car (13/16") wheel nuts?
If not, which type of socket should be used with the torque wrench?
Old 05-03-2015, 09:55 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: torque wrench socket
the air impact puts more stress on the socket than torquing it to correct torque so go ahead and use the same socket to torque them
The Following User Says Thank You to Crvett69 For This Useful Post:
marisalee (05-03-2015)
Old 05-04-2015, 07:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
What type of car do you have? It seems just about all lugnuts have migrated to metric over the past several years. Are you sure you shouldn't be using a 19mm or possibly 21mm socket on those lugnuts?
If you're not using the correct socket, some of that torque you are applying could be going to deforming the nut, and over time you might end up damaging them as well, especially removing them with an impact if the socket isn't correct.
-Rod
Old 05-09-2015, 07:46 PM
-Rod
It is 1998 Toyota Camry.
Old 05-10-2015, 08:57 AM
shorod's Avatar
SHO No Mo
I can just about guarantee you that you are using the incorrect socket for your car. It will be either a 19mm (most likely) or a 21 mm. Since 13/16 inch comes out to slightly less than 21mm, I suspect 19mm is correct. Using that 13/16" socket with an impact is likely to cause damage to the nuts over time.
-Rod
