Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-03-2015, 01:03 AM
teegolf teegolf is offline
2008 Impala Engine Oil Leak
Have a 2008 Impala, 3.9 engine, 182K for miles. Trying to chase down engine oil leak. Looks to be the oil pan towards the right side. Engine support under pulley end of engine gets oily first and then it spreads all over the oil pan area and then drips. Crank pulley seal has been replaced and that is not the source of the oil. Do not see any sign the oil is coming from higher up on the engine. Looking for any ideas or what others have seen so I have an idea what to attack. Thanks!
Old 05-03-2015, 02:45 AM
MikeCStig MikeCStig is offline
Re: 2008 Impala Engine Oil Leak
Oil pan or oil pan gasket.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 05-05-2015, 12:41 PM
rkvons's Avatar
rkvons rkvons is offline
And you know for a fact that it is not coming from the crank shaft area? That seal replacement could have been done wrong.
Old 07-22-2015, 09:41 AM
Black_Blade Black_Blade is offline
Maybe look at the oil pressure sensor, the innards can wear out and they begin to leak. Also the gasket behind the oil filter adapter is good place to check.
2002 Dodge Dakota 4x4 3.9L
