Old 05-02-2015, 02:53 AM
DrRadar DrRadar is offline
Just a guy
A/C O-ring lube
The service manual says to lube A/C o-rings and threads with 525 viscosity mineral oil. It specifically says to not use PAG oil.
I can order 525 mineral oil through Buick for $21 (amount unknown - probably a quart - way more than needed).
NAPA has 500 viscosity mineral oil for $10/quart. The label says for R-12 systems and lists Grand Prix through 94. Is that oil acceptable for a R-134a system?
Are there any other lubricants that can be used?
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
Old 05-02-2015, 07:24 AM
Tech II Tech II is offline
Re: A/C O-ring lube
Never used it, but someone told me about it....can't see buying a quart of mineral oil.....
http://www.acsource.com/nylogsealantpnrt201bblue.aspx
The Following User Says Thank You to Tech II For This Useful Post:
DrRadar (05-02-2015)
Old 05-02-2015, 09:28 AM
DeltaP DeltaP is offline
Re: A/C O-ring lube
Are there any other lubricants that can be used?[/quote]
Ester oil.
The Following User Says Thank You to DeltaP For This Useful Post:
Old 05-09-2015, 04:55 PM
Just a guy
Re: A/C O-ring lube
Gonna use R-12 refrigerant oil that I already have to lube o-rings. Bottle doesn't identify it as "mineral oil" but I've seen R-12 oil online identified as mineral oil. I'm thinking should be fine just to lube o-rings.
Lloyd
