reasons for long crank
What are all the most common reasons for a longer crank when starting a car? I just noticed after servicing my air filter that it cranks longer than usual.
Re: reasons for long crank
Poor fuel delivery due to bad fuel filters, worn out pump, minor leakage, or gunked up injectors.
Or poor air flow due to an air filter in need of replacement, but since you just did yours, I would check to make sure it's the right filter for your car. The only other reason I can think of is temperature. If it's really cold outside (like below freezing) and your car has been sitting in that for 8+ hours, it's perfectly normal that you have to crank the starter for longer. Although In Albuquerque, I doubt that's the issue.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!" -James May, in an old, worn out Lamborghini purchased for less than £10,000. |
