Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 04-29-2015, 01:32 PM   #1
tinkering
In the 200 Club
tinkering's Avatar
A/C Compressor Screaming 1993 TransSport
I didn't have time to replace the A/C compressor and reload the refrigerant and all that so I removed the compressor and replaced it with an 'A/C Compressor Bypass Pulley' $60.00 from the auto parts store. There were no shorter serpentine belts listed for non A/C applications. The pulley was easy to install but the compressor was a devil to get at for removal. It is down underneath. There was a very tricky mounting bolt that I had to use two or three 6 inch 3/8 drive extensions with a U joint between the first and second extension. This was VERY VERY tricky. I am going to recommend that you remove what you have to from the top side in order to gain access from the top. It might include removing the radiator shroud and some hoses, and whatever.
I used bolt cutters to remove the coolant hose pipes because I have no intentions of ever replacing the compressor (in our climate we might use A/C half a dozen times a year). DO NOT CUT THE LINES OF A SYSTEM THAT IS FULL OF REFRIGERANT. Have the system purged.
Note: Maybe there could be a shorter belt available from another application like a Buick car or something. A shorter belt might allow you to just leave the compressor in place and bypass the pulley. It depends on the serpentine configuration.
Please let me know how it goes for you, even if it is years down the road. I don't care how old the thread is.
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
tinkering is offline   Reply With Quote
Old 04-29-2015, 03:33 PM   #2
sergeimoskva
Re: A/C Compressor Screaming 1993 TransSport
Hi!
If you have the engine 3.8 l.then the length the belt (without compressor) is 1815 mm.
belt:
SKF - VKMV 6PK1815
Bosch - 1 987 946 072
Jp Group - 1518102900
Febi - 39794
sergeimoskva is offline   Reply With Quote
Old 04-29-2015, 03:51 PM   #3
tinkering
In the 200 Club
tinkering's Avatar
Originally Posted by sergeimoskva View Post
Hi!
belt:
SKF - VKMV 6PK1815
Febi - 39794
I do have the 3.8L. That is great information serge! Where did you find that? It is too late for me this time but not others. Thanks a bunch.
1959 Dodge Mayfair
2004 BMW 330i
Old 04-29-2015, 04:29 PM   #4
sergeimoskva
Hello.
This information was excerpted with the Russian site.
are here ... http://www.auto-olds.ru/forum/viewtopic.php?p=50647
Old 04-29-2015, 04:50 PM   #5
tinkering
In the 200 Club
tinkering's Avatar
Hello.
I can't read any of it. Is there a way to translate the site to English?
1959 Dodge Mayfair
2004 BMW 330i
Old 04-30-2015, 01:56 AM   #6
sergeimoskva
Hi!
Link to website with the translation....
https://translate.google.ru/translat...647&edit-text=
Old 04-30-2015, 05:57 AM   #7
LMP
LMP's Avatar
yes the info about the 3.8 without the A/C was not listed for TS because all of 3.8TS came with A/C. I had found it in the Buick or Oldsmobile listings. 72.5", PN 725K6 . I do have a 72" belt that I use for winter. the 1815mm (71.5") mentioned above is a bit too short in my opinion because my 72 is indeed a bit shorter than ideal and i have to crank the tensionser a bit tight... (the ideal 72.5 was not available at the store I went to)
http://www.automotiveforums.com/vbul...d.php?t=346613
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
LMP is offline   Reply With Quote
The Following User Says Thank You to LMP For This Useful Post:
tinkering (04-30-2015)
Old 04-30-2015, 08:53 AM   #8
tinkering
In the 200 Club
tinkering's Avatar
Hi!
Thanks for that. Interesting reading it is.
My idea was correct about the car application.
I will know for next time
1959 Dodge Mayfair
2004 BMW 330i
Old 04-30-2015, 08:57 AM   #9
tinkering
In the 200 Club
tinkering's Avatar
Thanks LMP.
I wish I wouldn't have been in such a hurry to get the job done. I could have saved a bunch of time and effort talking to AF. Haste makes waste.
Talk to you later.
1959 Dodge Mayfair
2004 BMW 330i
Old 04-30-2015, 09:31 AM   #10
sergeimoskva
Hi! I wanted to add.
If to deliver 72" or 72.5", I think, through the 500 miles times are will stretch. And it will sag. A 71.5" times are, it is difficult put on, but after 500 miles times are accept the desired shape and the tension
It is written so the people who set times are.
Good luck to all!
The Following User Says Thank You to sergeimoskva For This Useful Post:
Old 04-30-2015, 09:34 AM   #11
tinkering
In the 200 Club
tinkering's Avatar
If to deliver 72 or 72.5, I think, through the 500 miles times are will stretch. And it will sag. A 71.5 times are, it is difficult put on, but after 500 miles times are accept the desired shape and the tension
Good luck to all!
That is good info. Thanks! See you in one of the other TransSport threads.
1959 Dodge Mayfair
2004 BMW 330i
