Old 04-19-2015, 04:14 PM
Kaden_Wilson Kaden_Wilson is offline
Exclamation 99 Honda accord
My 99 Honda Accord typically gets 350+ miles to the tank but recently it's been getting 250 or less to a tank. The check engine light is not on and car is running the same as it did before the the problem. This started about 1 week ago. Any ideas what could be the problem??
Old 04-20-2015, 01:17 PM
MikeCStig MikeCStig is offline
Re: 99 Honda accord
This sounds like what happens when the ecu comes unplugged. If the computer loses communication with the engine it sort of assumes worst case scenario and tells the fuel system to feed more fuel into the engine than necessary. The engine will run fine in this situation, but it will burn more fuel.
What you'll have to do is get the code off the computer to point you in the right direction. It's pretty easy, it just involves plugging in a code reader and finding out what's acting up, or if the ecu is just unplugged altogether. Some shops will actually plug in and check your ecu for free.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
