Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-14-2015, 08:10 PM
chuck's chuck's is offline
Lamp Out Warning with Turn Signal
2002 Dodge pick up constantly gives me this warning when the park lites are on and then use a turn signal. All lamps do work and the front control module has been changed. this is driving me crazy. New technology!!!! Any suggestions or anyone have similar problem that found a solution?? Thanks.chuck's
Old 04-15-2015, 04:36 PM
aleekat aleekat is offline
Re: Lamp Out Warning with Turn Signal
Are all the bulbs the same brand?
Post back, that's what makes Forums Work.
Old 05-30-2015, 11:08 AM
Is that critical for this system? I do not think that the bulbs are all the same brand.
Old 05-30-2015, 02:28 PM
If you replaced a bulb recently and got this error again, replace in pairs. It really doesn't know a bulb is out, just a difference in resistance/voltage across the circuit.
The Following User Says Thank You to aleekat For This Useful Post:
Chris Stewart (05-31-2015)
Old 05-31-2015, 12:47 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
You didn't happen to put LED bulbs in did you? If so then that would be your cause.
