Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-12-2015, 02:34 PM
m-37bruce's Avatar
m-37bruce m-37bruce is offline
Pinion Service
Greetings,
Anybody have any ideas or opinions about this, is this something that a novice should attempt? Pinion Service, new gaskets, go through the entire rear end.
m37bruce
1953 Dodge M-37, W/oW Dept. Of The Navy
Old 04-12-2015, 03:46 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Pinion Service
What is it that you want to do? Why do you want to "go through" the rear axle?...There are tools needed to remove carrier side bearings and the inner pinion bearing. Tools also needed to measure gear backlash when setting up the rear end and also for checking bearing preload. This is not something I would recommend someone to do "just because".
The Following User Says Thank You to gmtech1 For This Useful Post:
m-37bruce (04-12-2015)
Old 04-12-2015, 09:19 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Pinion Service
Setting the pinion depth requires the tool for determining the pinion depth then shims to set it up.
There are still a few hot rod shops that can set up a Dana 60/80.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
The Following User Says Thank You to Chris Stewart For This Useful Post:
Old 04-12-2015, 09:21 PM
m-37bruce's Avatar
Re: Pinion Service
I'm guessing I'm going to bite the bullet and pay my mechanic to do this?
m37bruce
AF - Advisor
Re: Pinion Service
Here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
Starts on page 242
Tags
2005 , pick-up
