Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-12-2015, 07:11 AM
IFallsRon IFallsRon is offline
98 Sub lower radiator hose
Pressure tested the system and found fluid running off lower hose where it connects to the water pump. I'm guessing replacement is a suck job. Am I correct that I need to take off the fan and cowling?
Old 04-14-2015, 07:27 PM
j cAT j cAT is offline
Re: 98 Sub lower radiator hose
replacing the radiator hoses is not all that hard. 98 model good amount of room. radiator should have drain. do coolant at this time . not all that common lower hose. upper hose is. maybe water pump leaking.
Old 04-15-2015, 06:55 PM
I haven't had any leaking since the pressure test. Change out pending.
