Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 04-11-2015, 08:59 AM
wtaylo1 wtaylo1 is offline
99 4runner keeps dying in traffic
I've got a 99 4runner with the 3.4 engine and it's gotten to where it wants to stall in traffic. It starts right back up. Runs fine on the interstate. No check engine light. I've changed the fuel filter, cleaned the throttle body, and cleaned the MAF sensor. Not sure what to do next. Any helpwould be greatly appreciated. Thanks.
Old 04-13-2015, 08:51 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 99 4runner keeps dying in traffic
Check the fuel pressure. May be your fuel pump. Also, check your Engine Coolant Temperature Sensor output.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-14-2015, 01:44 PM
I'll check those and let you know the results. Thanks for the advice.
Old 05-14-2015, 09:11 AM
Well, I got it fixed. Here's what happened. The day after I posted the question asking for help, I finally got a "check engine" light. I have no idea why it didn't come on immediately, but it didn't. According to the code, the maf sensor was a possible culprit. I changed it out and the problem went away. Thanks so much.
Old 05-15-2015, 06:59 PM
Brian R.'s Avatar
Resident Chemist
The MAF sensor will trigger a 2-trip detection code. It doesn't trigger immediately. For future reference, sometimes you can clean the wire inside the sensor and it will solve the problem.
