Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2015, 03:50 PM   #1
japitrucha
98 Mustang 3.6 Automatice dies when put in reverse
The car idles fine in park, neutral, and drive, but dies when I put it in reverse. Every mechanic I have called in a fifty mile radius has no clue why. The error codes it threw were "Intake Air temperature sensor circuit high" and "Mass or volume Air flow "A" circuit low." The guys who did the test say these codes don't apply to the problem I am having. Trying everything. Anyone else have this problem or know what it could be? Thanks
japitrucha is offline   Reply With Quote
Old 04-11-2015, 10:14 PM   #2
MikeCStig
Re: 98 Mustang 3.6 Automatice dies when put in reverse
Maybe a leak or clog in the valve body? Torque converter maybe? Have you checked the fluid? When was the last time you had your transmission flushed?What happens if you shift into drive first then into reverse from there?
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
