Old 06-29-2003, 11:50 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Down Pipes?
Who makes a good down pipe that is 3" and will hook up to an Apexi N1 exhaust system?
Old 06-30-2003, 12:05 AM
AeroEclipse's Avatar
AeroEclipse AeroEclipse is offline
Send a message via AIM to AeroEclipse Send a message via Yahoo to AeroEclipse
Road Race Engineering has a downpipe that bolts right up to the Apex N-1. But its 2.5" to the flex section part of the downpipe and then the rest of the downpipe is 3"
Here's a link. http://www.roadraceengineering.com/eclexhaust.htm
Old 06-30-2003, 07:06 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
www.rnrracing.com
Kris
2012 Genesis Coupe 2.0t
Old 06-30-2003, 10:29 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
wouldn't the apex-i 3" downpipe fit onto a n1 exhaust becasue the same company makes both these products??
1
Shift_BOOST
97 s14
Old 06-30-2003, 01:22 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Yea,but that pipe is a rip off.
Old 06-30-2003, 01:29 PM
turbo2nr's Avatar
why is it a rip off?
Shift_BOOST
97 s14
Old 06-30-2003, 01:42 PM
Spoken like a hater
YES it necks to 2.5, but it works fine. Hell, it flowed enough to give me massive creep with a 16g/34mm flapper
Kris
Old 06-30-2003, 05:48 PM
95_GSX's Avatar
what pipes are you guys running?
Old 09-07-2003, 01:13 PM
95_GSX's Avatar
i am thinking of running a apexi-N1 down pipe and custom 3" exaust after that into a apexi-N1 muffler.
your thoughts???
oh and would this downpipe switch between a t-25 and a 14b???
Old 09-07-2003, 03:50 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Im sure you can find cheaper DP's than the Apexi. But it will be fine.
You will definetly see some creep, after installing it though, get ready to port the O2 housing.
Yes it will work on both the T25 and 14B
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 09-08-2003, 12:53 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
I'm running a 3" O2 eliminator downpipe, best downpipe u can get . I have an Apexi exhaust too, but that have nothing to do with the downpipe bolting up though since the downpipe bolts to the catylic converter....................well thats unless you a cat eliminator DP
-Agim
Old 09-08-2003, 09:35 PM
kjewer1 kjewer1 is offline
AF - Advisor
The RRE pipe is a great option, and it is flanged for the Apexi (they use a slightly different flange). Avoid anything designed to bolt up to a stock converter, that garbage is all less than 2.5" I use the RRE pipe. Avoid the Apexi DP, the flex section is WAY to short. That is why they are famous for breaking there. Shyte, IMO. Looks good otherwise. The flex section is the most expensive single component in a DP, so its no surprise when companies skimp there.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-09-2003, 01:28 AM
95_GSX's Avatar
hey thanks for the info i will go and check RRE's DP tomarrow. thanks.
Old 09-09-2003, 09:37 AM
Re: Down Pipes?
You've got me worried now. I'm going to have to add a flex section check to my weekly leak check
Kris
Old 09-09-2003, 09:44 AM
AF - Advisor
hehe, funny how this stuff adds up I did a 6 bolt swap on a car with an apexi DP, and it was still holding after a year or so. So there is hope, but it's just something to be aware of.
Kevin Jewer
