Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-03-2015, 03:58 PM
Butters16 Butters16 is offline
Smile 2002 impala battery drain
Car has a drain that kills battery over night. Fuse for cluster/BCM in driver side fuse panel gets rid of drain. Didn't know if there is a common issue for the car to look for . Thanks
Old 04-04-2015, 08:59 PM
la1's Avatar
la1 la1 is offline
Re: 2002 impala battery drain
None that i have heard of, so the fuse is for the BCM ?
Old 04-06-2015, 11:43 AM
In owners manual it says cluster/ BCM for that fuse
Old 04-06-2015, 08:11 PM
Blue Bowtie's Avatar
Registered Offender
Is this the 10A fuse? If so, what is the current draw in standby mode? If if is over 50 mA there may be a problem. However, initial current after shut-down and for about five minutes afterward can be higher. It should drop to 35-50 mA after that.
Old 04-07-2015, 07:32 AM
Yes it is the 10 amp fuse, it draws 1.64 amps all the time and kills battery in a few hours(overnite)
Old 04-07-2015, 11:29 AM
I checked all the normal stuff < glove box , truck and hood lights to make sure they are going off. Unplugged the truck latch and made sure the interior lights cycled out(also that the cluster lights shut down.
Old 04-07-2015, 01:04 PM
aleekat aleekat is offline
Bad diode in the alternator can cause battery drain but still provide proper charging voltage during testing.
Post back, that's what makes Forums Work.
Old 04-08-2015, 11:23 AM
Not the alternator unwired it still had drain
Old 07-22-2015, 10:25 AM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
This may sound dumb but start unplugging items in that circuit. If the drain stops watching a VOM for indication then the part you unplugged is at fault. Process of elimination.
John
Happiness is driving a Chevrolet!
