Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-30-2015, 03:19 PM
jburtonpdx jburtonpdx is offline
04 Impala 3.4 cooling issue
behavior I see:
engine starts and drives fine
temp gauge at start is low progresses up when cold and warming up as normal
temp of heater or defroster is cold even when temp gauge progresses up
when engine temp hits about 200 the air from heater/defroster warms up instantly
engine temp then starts to drop down to about 180 where everything gets cold again and temp begins to rise to about 200 where it warms up and starts dropping....
this cycle just repeats...
Old 03-30-2015, 03:50 PM
aleekat aleekat is offline
Re: 04 Impala 3.4 cooling issue
Check coolant levels. Thermostat or bad cap.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
jburtonpdx (03-30-2015)
Old 03-30-2015, 08:48 PM
Tech II Tech II is offline
In addition to what the Kat suggested, feel the heater core hoses....when you have no heat, BOTH hoses should be hot.....if outlet is cooler, then you either have an air pocket due to a leak, or a restricted heater core....
If both are the same temp, check heater door operation, especially if auto temp.....
