Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-29-2015, 09:28 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
Intake gaskets replaced. Now squeal
1998 v6 3.8 upper and lower intake gaskets replaced last week by my cousin. Now when it warms up and you shut it off is squeals. Someone said it could be the gasket isn't seated right and it's sucking air from the crankcase? Any other ideas? It squeals after the engine is shut off for a few seconds.
Old 03-30-2015, 10:07 AM
65comet's Avatar
65comet 65comet is offline
Re: Intake gaskets replaced. Now squeal
The PCV valve should take care of the air movement. If it is stuck closed, then probably one of those new gaskets has a small leak, or has been forced to have a leak, because of the PCV. They are usually cheap, I would get a new one anyway.
