Old 03-25-2015, 09:07 PM
NotWellTaught NotWellTaught is offline
swapping motor manual / auto.
I want to swap the motor from a 91 geo metro manual trans. into a 94 geo metro auto. trans. Is there anything I might should know? Can it be done easy enough? Any tricks? Please help, thank you
Old 03-25-2015, 10:48 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: swapping motor manual / auto.
you will need to transfer the intake manifold, probably the distributor and need to transfer the spacer plate and flexplate to the the new engine. spacer plate is a 1/4" thick spacer that fits between flexplate and rear of the crank, usually have to pop it off with a screwdriver, will also need to swap the right side mount and bracket
