Old 03-25-2015, 12:10 AM
SpellsingGeo SpellsingGeo is offline
Eating Camshaft Position Sensors (Ignition Pickups)
Twilight zone:
I present to you now, for your review, a 1993 Geo Metro, 1.0 L 3 cyl with automatic trans and A/C. It is a Vin Code 6 Engine (5 bolt crank pulley).
This car stopped running on the road without warning. When I finally took off the distributor I discovered a spiderweb of copper wire that apparently came from the Camshaft Position Sensor (some call it the ignition pickup and others erroneously call it a "module.") Full Service Manual says it is indeed the Camshaft Position Sensor.
I thought, no problem, must have worn out or maybe something wrong with the signal rotor. I took the distributor out of my other 1993 geo metro and installed it in the ailing one.
Cranked it twice, it almost started then just died.
When I took off the distributor, would you believe what I found?
It happened to the NEW distributor. Copper wire spiderweb!
What is causing my distributor to eat these sensors? It cannot be mechanical, it must be electrical.
Does anyone have a clue?
Oh, here's some example pictures for you.
Old 03-25-2015, 01:59 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Eating Camshaft Position Sensors (Ignition Pickups)
thats the pickup coil its shredding. i would check all the engine grounds and also make sure ignition coil isn't shorted out
Old 03-25-2015, 09:57 AM
Thanks for the advice. You're the second person to tell me to check the grounds. The component is called the "cam position sensor" in the FSM.
I copied and saved this diagram straight from the FSM.
Tags
camshaft , distributor , ignition , position , sensor
