Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-23-2015, 09:57 PM
sbriar sbriar is offline
ck engine,Vsc,trac light on
I have a 2007 Toyota Camry LS that says check vsc system. the check engine light, vsc and trac lights are all three are on. That is a concern but another big concern is that is sometimes runs sluggish and acts likes it wants to stall. ? I hope someone can help out with this, Thanks!
Old 03-23-2015, 10:18 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: ck engine,Vsc,trac light on
May be one or more of your ignition coils. See what code is stored in the ECM.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-25-2015, 03:34 PM
Brian,
had the engine codes ran today.
(Advance Auto)
P0301 thru P0306
and also P0356
Thanks,
Steve
Old 03-25-2015, 03:55 PM
I did some reading on code P0356,
do you think replacing ignition coil 6 would fix this?
Old 03-25-2015, 08:29 PM
Brian R.'s Avatar
Resident Chemist
It's possible
Old 03-26-2015, 10:18 AM
somick's Avatar
somick somick is offline
Try to swap it with the different cylinder and see if the code will move.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-30-2015, 05:07 PM
Update
I replaced coil pack on #6 and all warning lights went away.
Did not have to reset anything, warning lights stayed off during first test drive
after replacing coil pack.
It has been almost two weeks now and no lights and car runs great.
Thanks Brian and Sam for your help!
Thanks,
Steve
Old 03-30-2015, 05:47 PM
Brian R.'s Avatar
Resident Chemist
You're welcome
