Old 03-22-2015, 12:21 PM
autojoe autojoe is offline
trail blazer question 2008 4.2
back month ago temp was 3 degrees ran through a big deep pool water on road way.abs activated and finally got truck stopped.there was a engine vibration issue and also sounded like a exhaust leak when under a load.it stayed frigid cold for couple of days bottom of engine was ice covered and after the outside temp went above freezing and most all of the the vibration and exhaust loudness went away.Does anyone know what caused this?also still have a small vibration issue that can be felt through the gas pedal and sometimes through the steering wheel.very subtle though.Did not have any before the ice problem.just had 4 wheel alignment but did not take away small vibration issue.any ideas would be appreciated.thanks joe
Old 03-23-2015, 01:06 PM
Schurkey Schurkey is offline
Re: trail blazer question 2008 4.2
Curious: If the temperature was 3 degrees, why was the water still liquid instead of frozen? If you were from Canada, I'd maybe think you were talking about 3 degrees Celsius.
Apparently, you had ice on the moving parts of the vehicle, and it caused imbalance or increased the transmission of vibration from one part to another which you felt and heard in the passenger compartment.
If the ice is gone, all the "usual suspects" remain--tire/wheel imbalance, tire out-of-round, driveshaft and U-joint balance and condition, etc.
Surprised you feel vibration in the gas pedal, since that's electronic.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 03-23-2015, 07:31 PM
its weird.....when increased rpm sounded like an exhaust leak that got louder under load.went away when ice melted.the vibration was bad until ice melted and now is not very noticeable and is very subtle.What ever it is maybe will get worse before I can diagnose.I was thinking flex plate with ice on it.it was 3 degrees(F)water run off hill side and road crew salted road.....water went and covered windshield and froze solid on windshield and car was coming other way and could not see road and abs was going off and could not stop truck for a long way went off road little trying to avoid other car that I could not see except the head lights through ice coated wind shield.Thank GOD I was not killed.Thanks for reply.
