Old 03-15-2015, 11:54 PM
l1driver l1driver is offline
Send a message via AIM to l1driver Send a message via MSN to l1driver
Engine Surge
I have a 00 Silverado Z71 Ext. cab, 4.8 motor and auto trans. 264,000 miles. I noticed recently when driving down the highway at times the engine wil begin to surge. Usually between 40 and 50 MPH. if i let off the throttle it will smooth out or if I give it more throttle it will smooth out. Any ideas what would cause this??
Old 03-16-2015, 06:49 AM
maxwedge maxwedge is offline
A990 racer
Re: Engine Surge
Do a full scan, sluggish o2 sensor is one possibility.
Old 03-16-2015, 07:32 AM
j cAT j cAT is offline
Re: Engine Surge
Originally Posted by l1driver View Post
I have a 00 Silverado Z71 Ext. cab, 4.8 motor and auto trans. 264,000 miles. I noticed recently when driving down the highway at times the engine will begin to surge. Usually between 40 and 50 MPH. if i let off the throttle it will smooth out or if I give it more throttle it will smooth out. Any ideas what would cause this??
Most all times surging is the fuel pressure low insufficient fuel.
check pressure 52-62pSI.. replace fuel filter . then use the techron injector cleaner.
make sure you have 1/3 tank of fuel at all times or more. if you operate with less than 1/3 often then the pump is most likely failing.
