Old 03-04-2015, 06:00 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Tamiya F40
Has anyone built this, gluing the hood shut? The big clear window, plus the fact that this car just looks like a total butthead when all closed up, means I'd rather not worry about the ill fitting panels and just sew it up. Any big challenges? I intend to add a rim around the bottom diffuser to line it up with the hood shell during final assembly (much better than plan A, to cut the diffuser off and just glue it to the rest of the body).
Thanks.
Old 03-04-2015, 07:44 PM
Veyron's Avatar
Veyron Veyron is offline
Re: Tamiya F40
Mine built up just fine. Clam shell actually opens and closes freely and fits to the lower rear nicely when closed. Just remember the rear window goes on from the outside....I've seen people brainfart and try to put in in from the inside. It's a decent kit IMO.
Old 03-05-2015, 09:07 AM
Hemi Killer Hemi Killer is offline
Re: Tamiya F40
Its not that bad of a kit. It takes a little bit to get the decklid to sit correctly but not enough to warrant gluing it shut. And thats coming from a lazy person
Old 04-03-2015, 02:06 AM
ferrariscale ferrariscale is offline
Re: Tamiya F40
Thanx for the heads up, I've just started this kit as well.
Old 04-04-2015, 08:32 AM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
Re: Tamiya F40
The engine lid is easily fixable. The biggest flaw on the kit is the inner window scoop towards the back. The kit calls for you to paint part of the clear window plastic red, but in reality that is a seamless part of the body. You'll need to cut or sand down the clear piece and then add some plastic and putty.
Old 04-07-2015, 09:29 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
Re: Tamiya F40
Thanks for the heads-up. Have one which I intend to build soon...after I recover from the two monogram F40s that I did. hahaha.
olly olly oxen free
Old 04-10-2015, 01:21 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: Tamiya F40
One of the turbos also needs work and if I recall correctly, is installed wrong according to the instructions.
MPWR's build is maybe the nest guide for this kit that I have seen.
AF's Guidelines
Read them.
Old 04-12-2015, 11:24 PM
Re: Tamiya F40
I bought some resin turbos from TDR Innovations on Shapeways. I will be replacing the kit turbos with those. MUCH better. I ordered 4-5 sets before I got the right size
