Old 03-03-2015, 08:32 AM
georges99 georges99 is offline
Need some advises to strip tamiya paint
Hi everyone !
I need some advice to trip Tamiya paint from a fujimi plastic kit.
I have use the Tamiya TS47 spray paint from a can, over primer.
Any good recommendations ?
Thank you in advance
George
Old 03-03-2015, 08:58 AM
joelwideqvist joelwideqvist is offline
Re: Need some advises to strip tamiya paint
I've used brakefluid with fine results.
Old 03-03-2015, 09:22 AM
griffin-gt40 griffin-gt40 is offline
I see you live in Canada too,
go to Walmart, find Super Clean, big purple jug ( use to be called Castrol Super Clean
put in big plastic container (like a 4L ice cream tub....I'd eat the ice cream first tho)
leave it for about 24-48 hours, pending on how old the paint is
paint should just flake off, I use an old tooth brush to scrub the body/parts to lift of the paint to expose any layers beneath, let is soak some more
make sure the wear gloves, the liquid pulls oils from the paints and it will do the same to your hands if you don't wear some gloves
big jug is about $20 bucks, lasts a very long time....its also good for stripping chrome plating too and will not hurt or melt plastic if you forget about it
David
The Following User Says Thank You to griffin-gt40 For This Useful Post:
georges99 (03-04-2015)
Old 03-03-2015, 11:42 AM
JimboCO JimboCO is offline
Another alternative is to use isopropyl alchohol
Old 03-03-2015, 12:48 PM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
I've always used Tamiya Paint Killer. If you put a tissue around the part(s), to keep the liquid in place, a few drops will do, and the paint will come off after 10 minutes, including the primer (and unfortunately also putty).
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Old 03-03-2015, 12:50 PM
ZoomZoomMX-5's Avatar
Tamiya sprays seem to strip easiest with the most inexpensive solution, aka 91% isopropyl alcohol (aka rubbing alcohol). The purple cleaner may not even touch it. Brake fluid should work.
My Fotki Album
Old 03-03-2015, 02:57 PM
Beakster's Avatar
Beakster Beakster is offline
Isopropyl alcohol is the way to go. Discovered that by accident... Whoops!
Current W.I.P - Tamiya 1/12 Yamaha YZR500
Old 03-04-2015, 08:07 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Isopropyl alcohol is the beat everything way to strip Tamiya TS paints. Nothing is more effective. It is also the thing for stripping acrylics.
Brake fluid would likely work- but brake fluid can do some pretty strange things to plastic. It's also unnecessarily toxic, and unnecessarily expensive. If you really want to repaint the parts, there are better options. Brake fluid is a great way to ruin paint- but that doesn't make it necessarily a good stripper.
Not sure that Super Clean or Purple Power will work well. They are great for stripping enamels and ok for acrylics, but often not so good for lacquers.
PHOTOBUCKET SUCKS
Old 03-04-2015, 08:49 AM
stevenoble's Avatar
IPA all the way, it will strip Tamiya TS with no problem. Brake fluid would work but it's not my preferred method. It can make the plastic brittle and can also make any dyes in coloured plastic bleed out.
Steve Noble
Old 03-04-2015, 01:39 PM
Hemi Killer Hemi Killer is offline
I have used brake fluid for a long time. The first time I tried the 91% alcohol, it was much better than the brake fluid.
Now I use brake fluid for enamels and Alcohol for the Tamiya lacquer. The brake fluid doesn't get the Tamiya in one shot and handling it is not good for you.
Old 03-04-2015, 06:20 PM
David
Thanks David !
Yes, i am from Montreal.
Thank you for the advise. Will do, ASP.
The paint is very recent, so it should be pretty easy to strip.
thank's again.
Old 03-04-2015, 06:24 PM
Thank you very much guy's.
Your suggestions are great.
Thank you everyone's.
Old 03-04-2015, 08:31 PM
MaRiO FDZ MaRiO FDZ is offline
Brake fluid is bad for plastic. You'll eventually get cracks all over till the piece crumbles. I learned the hard way.
Degreaser won't attack Tamiya TS paints.
The only thing I've found to work is SURPRIsingly, 90%+ Isopropyl Alcohol. Dip the piece overnight and scrub with a toothbrush. Some scrub work is needed but it works.
Trust me
Old 03-05-2015, 11:01 PM
nascar49's Avatar
nascar49 nascar49 is offline
Send a message via AIM to nascar49 Send a message via Yahoo to nascar49
I have in the past had the Purple cleaner remove Tamiya Paint , but I think I just got lucky , it will however remove their primer.
I am going to be one more person say 91% IPA, that is what you need, dont bother trying to use purple cleaner, dont bother trying to use oven cleaner.
Also, it may take some time for it work, I have had it work over night, or sometimes, takes a week or longer, it all depends.
Pheedens Garage on Youtube
https://www.youtube.com/channel/UC4j...J8vUP1ZaHP32ig
Old 03-07-2015, 11:42 PM
John18d John18d is offline
Georges - I'm in agreement with the majority of replies - Isopropyl Alcohol 91%
Make sure you get the 91% not the 70% "rubbing" alcohol
You can get it at Walmart for about $3.00 for a liter and you can soak the item to be stripped and then pour the IPA 91% back in the bottle and reuse it again and again
Hope this helps - I think it is the "BEST" method for Tamiya TS paints
John
