Old 02-24-2015, 08:26 PM
ScottForster ScottForster is offline
PPG Envirobase
Hey guys, haven't posted in an eternity, but I am wondering if PPG Envirobase paints can be used on model cars without problems...My plan is to use a Duplicolor primer and since I work at a bodyshop paint the models with leftover paints from cars. My supervisor is cool with the idea.
Old 02-25-2015, 02:41 AM
Hemi Killer Hemi Killer is offline
Re: PPG Envirobase
I'm not 100% sure, but I think as long as your primer it and the paint is compatible with the primer then it will be ok.
Old 03-03-2015, 12:52 PM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
Re: PPG Envirobase
I would simply test it on some left over plastic part. Prime, paint and clearcoat, and see what it looks like.
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Old 03-07-2015, 11:45 PM
John18d John18d is offline
Re: PPG Envirobase
Scott - what are the "solvents" in those PPG paints??
That should tell you if it is safe for plastics
and always test first - you can use "white" styrene disposable spoons
Hope this is helpful
John
Old 03-08-2015, 07:37 PM
Re: PPG Envirobase
John
The envirobase line is a water based paint...I am assuming it cleans up with water
Old 03-08-2015, 07:59 PM
Re: PPG Envirobase
It might be a water/alcohol blend - in general water doesn't want to go thru a "gun" paint gun without splattering - it doesn't mix well with compressed air.
I've never used the water based automotive paints - they started coming out in the mid 90's when I was racing superbikes
John
