Old 02-11-2015, 11:24 AM
Hemi Killer Hemi Killer is offline
My custom spray booth
I have built several spray booths over the years, with none of them being adequate. Last year, my parents bought me an Artograph 1530 spray booth for my birthday. They aren't cheap, but they work well. The problem is I live in the desert. The Artograph booth is a down draft, so while it works well, it pulls dust straight down.
I spent way too much money and way too much time doing this, but in the end I am satisfied. I will probably build it again some day, but with Lexan instead of acrylic.
Here's the booth. It is 30" long and 15" deep, with 2 fans in the bottom that pull 470 CFM. When you add the 3 stage filters, it's considerably less. It does surprisingly well with spray cans as well as the airbrushes. I can paint with spray cans for hours and the smell will be present, but MUCH less than before, and it will never leave the room.
There are 3 filters. The first on top is the disposable pre-filter. This catches all the paint particles. It is very thin. The next filter is a fluffy whie fiber filter to catch the rest of the paint that comes through. the last filter is a black charcoal filter. This controls the odor.
1/12 Chevy body
This is a great booth, but it wasn't enough. I need to keep the dust out while the paint dries on the bodies.
Angle aluminum from Home Depot
Cutting everything to size and drilling the holes
Acrylic sheets from Home Depot. I ended up buying double the acrylic because I kept breaking them. I didn't buy Lexan because it was more expensive, but it wouldn't have shattered like the acrylic.
First fitting
I didn't think ahead and I drilled all the opposing holes in the same spot. The screws ended up hitting each other, so I had to disassemble the whole thing and re-drill half the holes. I am not, nor should I ever be an engineer.
The second most exciting moment of my modelling career
The Most exciting moment of my modelling career was removing the protective film. This thing is a beast.
Now I have this awesome spray booth, but where will it vent? I'm sick and tired of raising the blinds and opening the window every time I paint. Not only is it 115+ degrees in the summer, it lets more dust and dirt in.
There was only one option (this is what I told my wife) Drill holes through the side of my house.
it took FOUR hole saw bits to make 2 holes. The lathe and stucco killed these things. So I spend nearly $100 to just make the holes exist
These are fittings for a dryer vent
Stuck them through from the other side
This is a flange for a dryer vent (I think) it fit perfectly
The flaps are closed by default. When the booth is on, it will open the flaps and vent outside and not let anything back in. Also, when not in use, no dust comes through.
This is what the outside looks like
The hoses are fitted with a snap-in fitting. I can remove them whenever I want
Here is my finished work area
I can spray sitting down or standing up. There is a LOT of visibility. I have since removed the 2 lights and added an High Intensity light to the ceiling.
The Following 4 Users Say Thank You to Hemi Killer For This Useful Post:
BVC500 (02-11-2015), eugene78 (02-13-2015), Tompidom (02-14-2015), tonioseven (02-11-2015)
Old 02-11-2015, 11:35 AM
joelwideqvist joelwideqvist is offline
Re: My custom spray booth
Wohaa! Really nice!
Old 02-11-2015, 12:03 PM
bradfordian bradfordian is offline
Incubated models?
Old 02-11-2015, 01:11 PM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
nice idea.
think if I hole the walls of my office here my wife will dress me in orange and behade me like hostages in syria.
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 02-11-2015, 02:16 PM
modellmaker.'s Avatar
modellmaker. modellmaker. is offline
That's a really nice spray booth.
well done.
modellmaker
Twitter, Instagram: #modellmaker
Old 02-11-2015, 02:21 PM
tonioseven's Avatar
That whole model room is like a dream come true!!
Old 02-11-2015, 03:21 PM
It's a model/office/guest room. I get 1/4 for the models. When my son is old enough, we will put the bed in his room and I will dominate the other half
The Following User Says Thank You to Hemi Killer For This Useful Post:
tonioseven (02-12-2015)
Old 02-11-2015, 06:20 PM
da_ashman's Avatar
EPIC setup!!!
Old 02-11-2015, 07:40 PM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
I wet my pants
Another day on the job!
Old 02-12-2015, 01:11 AM
John18d John18d is offline
nice booth Hemi Killer
John
Old 02-12-2015, 03:27 AM
countach79's Avatar
countach79 countach79 is offline
Real nice mate, looks great
Old 02-12-2015, 05:27 AM
chris24 chris24 is offline
Awesome ! Pity my walls are 3 times thicker and made of bricks and cement...
Old 02-12-2015, 10:26 AM
You can use a diamond core bit made for granite.
