1999 chevy suburban w/ 5.7L cranking problem
what could make my 1999 chevy suburban with a 5.7L engine act like it want crank it turns over like the battery is dead. I replaced the battery and the starter but it still drags then it will catch and start. After it starts it runs perfect. Then when I cut it off. The same problem occurs. Could this be a timing issue?
Re: 1999 chevy suburban w/ 5.7L cranking problem
Most likely a loose battery cable connection or a bad cable. Another area is the starter relay and its connections in the under hood fuse/relay box.
Try this for a test of the electricals. Turn the headlights on bright. If they go out or very dim when cranking, there is an electrical issue. I don't think that this is a timing issue!
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
normal timing error would cause poor engine performance with these. with a distributor over 175K miles best get new one any way as the bearings do fail. make sure the starter is not dragging on the flywheel. make sure you set the clearance properly. if unsure place a shim on the starter mounting see if it cranks faster. If your battery or starter cables are green on the copper/connectors then these may also be your problem. |
Thanks for all the responses. Its was the distributor cap and rotor Causing it to cross fire. I changed both of them and it started cranking up perfectly.
