Old 01-31-2015, 07:10 PM
mega8man's Avatar
mega8man mega8man is offline
distributor installation 98 5.7
Hi all, I'm trying to replace the distributor on my 98 5.7 vortec. I am only replacing it because my truck was running real rough and when I started looking at possible problems I noticed that my distributor was pretty much not even bolted down. I am amazed it was still running. Anyways I have the engine at tdc on cylinder 1 and I can get the distributor to spin in but not where it is supposed to be it will only go in two positions, both of which are not on cylinder 1, I read that it is the oil pump and that I need to spin it with a flat blade screw driver but the driver just bottoms out and never catches on anything, is there something I'm missing? Thanks
Old 01-31-2015, 08:19 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: distributor installation 98 5.7
if you are sure you are on compression stoke you can bump engine over till dist drops down the last 1/4" or so then can use a timing light to set it. if all it does is backfire its probably not on compression stroke so your 180 degrees out.
Old 01-31-2015, 08:26 PM
mega8man's Avatar
It only seems to be off by about 60 degrees, the spiral gears will mesh at any position I want them too but will stop about an eight in short in all positions except two
Old 01-31-2015, 08:34 PM
Crvett69's Avatar
get dist as close as you can to right point then if you turn engine over it will turn the shaft until it matches the oil pump slot and drop down. either that or get a real long regular screwdriver. look down the hole with a light and turn the oil pump shaft a little then try distributor again. might take several trys to get it right. if you do spin the engine over by hand pr with starter just let dist sit the loose, don't push down or use hold down till it drops into oil pump slot
Old 01-31-2015, 08:45 PM
777stickman 777stickman is offline
Lots of info here. Need to follow all the procedures to get it close. A timing light for this install is of no use. What is needed is a high end scan tool that can access "cam retard" or "cam offset". This is the only way to set "base" timing for the vortec motors. The spec is 0* +/- 2* @ 1500 rpm.
If you don't get it right you'll end up with a P1345 code.
https://www.google.com/?gws_rd=ssl#q...+98+5.7+vortec
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
